QUOTE(mikelsr @ Oct 24 2006, 05:20 PM)
Replacing the fuse block is a good idea. I have to search the club store to see who makes a replacement and get one ordered.
Mike - If you are referring to my post, just replacing the fuse block won't do what I am talking about. You don't need to replace that fuse block. The only upgrade I have seen is where the fuses were converted to the late-model blade-style fuses (like the GM block I have).
The issue I am referring to is where the fuse is within your system. The fuses on the 914 are between the lights and the switch, not before the switch which would be better IMO. Then, any grounding (other than before the fuse obviously) will blow the fuse, not melt the wires.
The other issue I think you/we are all combatting is the fact the wire is so old and with age, the coating becomes more susceptable to failure/burn-through.
I tried like hell to locate color-coded wire and thought I found a distributor, but then he never got back to me after I gave him a list of the porsche colors.
So good luck with that one!
Adding the extra gauges didn't help either as there is a lot of load on that switch. The lights would be fine to add (I would guess) as they have low draw, but I would suggest adding any 12V power sources from a lower load item, like maybe the brake switch post or something "intermittent" (brakes aren't always on, the reverse lights tie into that aren't always on, etc). I think you mean you just added power for the lights... probably not an issue.
