Carlitos Way
Oct 26 2006, 06:07 PM
I'm hosting a BBQ and asking for help on November 12th.
I'd like to accomplish the following:
1) Drop the engine/tranny, remove and replace oil pump and front seal (behind the fan).
2) Remove and Replace Rear calipers and change pads on front (BMW 318i) calipers.
3) Replace Brake Proportioning Valve with a T Valve.
4) Bleed brake system.
5) Reinstall Engine.
6) Test out new BBQ Grill.
If time allows, a short "test" run down Santa Susana Pass and Box Canyon.
Any volunteers?
Carlitos Way
Oct 26 2006, 11:47 PM
Did I mention Tri Tip?
Crazyhippy
Oct 27 2006, 05:03 PM
I might be @ a wedding the 12th... if not i'll be there.
BJH
Carlitos Way
Oct 27 2006, 10:23 PM
QUOTE(Crazyhippy @ Oct 27 2006, 04:03 PM)
BJH
Kewl Beens. Thanks for the bump!
Crazyhippy
Nov 7 2006, 01:22 PM
ok, i'm there... who else is coming up??
SLITS
Nov 7 2006, 01:33 PM
QUOTE(Crazyhippy @ Nov 7 2006, 11:22 AM)
I'll see what I can do to be there. Remember, you stay at home and send the S.O. ................
Crazyhippy
Nov 7 2006, 01:40 PM
she might show up for moral support...
Think more people will show if she's in a cheerleader outfit??
SLITS
Nov 7 2006, 01:42 PM
QUOTE(Crazyhippy @ Nov 7 2006, 11:40 AM)
How 'bout a string / thong bikini?
Crazyhippy
Nov 7 2006, 02:11 PM
You have to talk her into it...
She looks damn good in one, and i might not want to work on the car then...
SLITS
Nov 7 2006, 02:15 PM
Slits (discarding his lecher outfit) ..... Yes, it's a photo shoot for the "2007 914world.com Ladies Calendar". Uh yeh, I'll keep my hands in my pockets.
Think that'll work?
Crazyhippy
Nov 7 2006, 04:48 PM
Kim says i'm "too funny about me showing up in a cheetleader outfit to carlitos thing"
You guys aren't being very convincing...
Help me help you.
And she will not be wearing anything less than a turtleneck and levis around slits...
SLITS
Nov 7 2006, 05:18 PM
QUOTE(Crazyhippy @ Nov 7 2006, 02:48 PM)
Saaaaaaaxxxy
Carlitos Way
Nov 7 2006, 05:59 PM
QUOTE(SLITS @ Nov 7 2006, 03:18 PM)
Saaaaaaaxxxy
My GF will be there... fully dressed...!!!
SLITS
Nov 7 2006, 07:20 PM
Well, ok .... it won't matter anyway. Being as old as I am:
1.) My eyesight is failing. The vision of scantily clad babes with wrenches would probably escape me anyway.
2.) My hearing is failing. If an indecent proposal was made I wouldn't hear it anyway and would probably respond with
3.) Being arrested for "assault with a dead weapon" wouldn't look good on my record.
4.) Child Molestation would look even worse.
I guess I'll stick to Hallmark Channel and grease.
Grimstead
Nov 7 2006, 07:36 PM
QUOTE(SLITS @ Nov 7 2006, 05:20 PM)
Now that was an image I did NOT want in my head...
Thanks for the TMI Ron.
Crazyhippy
Nov 8 2006, 12:49 PM
alright, so who else???
You've got beef, cheerleaders, and a fellow teener needing some help.
BJH
Crazyhippy
Nov 10 2006, 06:35 PM
BUMP???
BJH
Carlitos Way
Nov 12 2006, 07:16 PM
Progress Report:
First of all, a big thanks to BJ (CrazyHippy) for all his hard work. We were successful dropping the engine. We removed the engine tin and fan shroud and we noticed some oil appeared to be coming from the front seal. We found some oil coming from the oil cooler so we replaced it with another oil cooler and new gaskets. While we were in there, we decided to replace the oil filter gasket. We also replaced the oil pump gasket and put everything back in place. Found a couple of interesting "surprises" while taking the engine apart.
For now, since the engine is out, we also replaced the passenger's side valve cover gasket. It was far from new, but not sure if it was also a source of leakage.
We had a couple of nice double burgers and then back to work. Put most of the engine back together.
The bad news is we didn't get done. I've got quite a bit of work to do still. While the engine is out, some more degreasing and ordering gaskets for the CV Joints. It also looks like I need new motor mounts.
Hopefully some time during the week I'll get a chance to get things back together.
Once again, a big thanks to BJ.
