jperret
Oct 29 2006, 01:02 AM
The 914 has lots of holes (1" up to 2" or so) that are filled with rubber stoppers. For example there are a lot in the front trunk.
Where can you get replacements for these?
GeorgeRud
Oct 29 2006, 09:55 AM
They may still be available through Porsche ( try part number 914.559.252.10), but Porsche has made many parts NLA in the past years.
I've also had good luck with parts from Brad Mayeur in E. Peoria, IL (914LTD), Auto Atlanta, or any of the other used parts vendors.
If nothing else, you should be able to find some sort of plug to close the hole at McMaster-Carr. It won't be original, but it will do the job.
Oct 29 2006, 12:31 PM
QUOTE(jperret @ Oct 28 2006, 11:02 PM)
not sure if porsche still sells them, but used ones should be plentyful.
try HPH, EASY and PartsHeaven ...
http://www.highperformancehouse.com/http://www.easypor.com/http://www.partsheaven.com/ Andy
E-Man
Nov 1 2006, 10:05 PM
How many do you need? I have a sack full somewhere around here from a sawzall party a few years back. Could be had cheaply if I can find them. -Mike
jperret
Nov 13 2006, 11:38 AM
Mike if you can find them let me know. Joe Perret joeperret@msn.com
dmenche914
Nov 13 2006, 12:42 PM
High performance House should have lots of them.
