Hi All
I am located in Sydney, Australia and have wanted to build a porsche 914 for Historic racing for a while now. Last weekend I found a Right hand drive car in Australia and purchased it. I had been left uncovered on the grass for around 4 years and is now rusty. The motor runs quite well and it has all 5 gears. I havnt driven it as the brakes are unsafe and it has a sticky throttle.
Pics of the car are at http://au.geocities.com/dpauperiseng/
I need some help!. Firstly with the body, my best guess is that this car has been flared, can someone confirm/deny this.
I am also guessing that the front brakes are VW type 1-3 discs that have been redrilled with superbug calipers. Again confirm/deny? If i am right, are the 914 brakes any better than this?
I beleive that the rear brakes are genuine 914
The engine came with the carb and manifold setup shown. I beleive it may be a weber, but the only markings I can find is the word 'weber' on the accelerator pump cover plate. Can anyone identify this? I must run either orignal carb/fuel injection. I am informed that the 1800 came out with twin single choke Solex 40 PDSIT. Is this correct?
The rear suspension has a sway bar which appears to be more or less forced in. Did these cars have a factory sway bar?
Also I need some parts, namly
- Two gyards
- Bonnet
- Rear filler piece (The bit that says VW Porsche 914)
- Solex carb set up
- 2nd hand or reproduction 4 stud wheels, hopefully 15x6?
What would be the best place to find this stuff.
Thanks in advance for any help
Daniel
