I locked up the engine in lil red so I haven`t posted lately(imBareAssed).Must have not been getting oil to the rear main.I found a small square of plastic in the oil pump,HAVE NO IDEA where it came from!I pulled the engine a few weekends ago today I finally split the case.Everything looks good but the rear main and #3 piston.Called Arias about a replacement piston(96mm flat tops)and a whole new set of rings.They are going to check but they quit making my pistons years ago.Headed to the machine shop to have the rods and crank checked out,rebalanced, polished for sure.What should I do with the rods;anything?
