QUOTE(gregrobbins @ Oct 31 2006, 09:59 PM)
Tell FlatVW that I will trade a complete d-jet system for that "core" motor in the green car.
Where is that thing, I think us vultures are starting to circle.
The cold start valve/thermo switch wiring might be different but you don't even really need that here in AZ. It will almost never be engaged. You could run the car without it, no problem. Even if its a temporary situation.
I think with the TPS, the 4 plug connector works in the 5 plug TPS. You just have to get it shifted left or right correctly. Not sure which direction.
As far as component locations, you're on your own. I have a junk 73 2.0 harness you could use to figure out those lengths and lengthen your 1.7 harness.
