No problem, I'll have a set waiting for you when you get tired of the squeaks and moans
seriously, make sure the set of poly bushing fit correctly, I installed a set a while back on Scott Carlbergs car and the damn things fit too sloppy and I had to shim the OD of the bushings with .02" sheetmetal, not a pretty repair, but it'll last for a few years or more. We had a few other options, but due to time and budget, I did what I know will work.
Options?
buy new trailing arms with "good??" ID's or make custom sized poly bushings (Racer Chris does this, and now I know why !!! )
The inside diameter of the trailing arms is not exact, and with the problem you described, one end might be ovalized due to the axle banging up and down on the tube of the trailing arm.
You have to trim the flange of the new bushings as well...the axle
must extend past both sides of the bushings by a few thou or the axle will not fully seat against the mounts.
I might have posted pictures of Scotts install, if not, I'll post a quick write up on Monday
