G e o r g e
Nov 3 2006, 07:54 PM
And with that being said
what would a good price be for a running 2.7 conversion? (how can i tell if it is a 2.7?)
less than 10?
>9?
>8?
>7?
>6?
>5?
and i know
but i don't go look at it till tomorrow.
davep
Nov 3 2006, 09:40 PM
Look to see how the engine is mounted at the front.
Look to see how the oil lines are plumbed.
Look to see how the throttle linkage is made up.
Exhaust system. Fit and finish. Get the engine number and code. That is a good start on what the engine started as. Since it is now in a 914, the guts of the engine may have nothing to do with the numbers on the case. After 30 years anything is possible.
Price is dependent on what exactly you are getting.
GeorgeRud
Nov 3 2006, 11:01 PM
A leakdown or compression test can give you some idea of the mechanical condition of the engine. Look for Carrera tensioner updates. Does it have headers or heat exchangers? 914 or 915 transmission? Flares, wheels, brakes? etc. etc. etc.
My guess would be anywhere from 10,000 up.
G e o r g e
Nov 3 2006, 11:24 PM
here's the ad
914-6 clone, 73 2.7eng, rebuilt webbers, susp, brakes, SS brake lines, elec ign., extra parts, short shifter, runs good, needs tlc (says rust to me)>7 asking price
why or what would i need to find to walk away ( besides rust )
pic shows 4 lug
TravisNeff
Nov 3 2006, 11:27 PM
The tub needs to be in good shape, a hotrod 2.7 is not worth much in a rotted tub. Also I would imagine that they changes to 5 lug - what did they use? suspension up to par with the engine? another factor. If all the conversion parts are top notch and have a car with a great paintjob, but some bad cancer or a bent tub - you start over with some conversion parts. Paint, bodywork and rust repairs can rival an engine build in a hurry. I would approach the purchase if the engine didn't matter at first, like it didn't matter if it was a 4 or 6. Once the car passes the test then persue the engine swap to add to the price.
G e o r g e
Nov 3 2006, 11:37 PM
QUOTE(Travis Neff @ Nov 3 2006, 09:27 PM)
i hear you on the tub, but if it was a stock 4 at 7k that needed tlc i wouldn't even think about looking at it.
SLITS
Nov 4 2006, 09:11 AM
Conversion:
Price of original car = ?
Oil Tank (stock) = $900+
Oil Lines .... = $300
Engine mount = $300+
Engine mounts = $100
HEs (stock) = $900+
Muffler = $300?
Shortened shift rod = $100
Bell crank accelerator assy = $100+
Webers = $1200
2.7 engine = $1000 - $2500
Suspension (5 lug +master +lines) = $900
Wheels = $400 - $600
Engine Tin = $350+
Labor to do conversion/welding/drilling/wiring = ???
Tuning to run right = ????
Electronic Ignition = $60 - $250
Guages = $100 - $500
Conversion Flywheel = $150 - $700
You can add it up and it can be done cheaper with a little shopping, but......
Allan
Nov 4 2006, 09:36 AM
When did Porsche start with the 2.7?
I thought it was '74.
davep
Nov 4 2006, 10:17 AM
2.7 did come out in the 1974 MY.
Porsche Rescue
Nov 4 2006, 10:31 AM
A running driving six conversion with a straight body, decent interior and no serious rust is a great buy at $7000.
