Eddie914
Nov 4 2006, 07:51 AM
Where was the fuel pump located on the original 914-6?
Was this the pump?
Thanks
Eddie
DNHunt
Nov 4 2006, 07:56 AM
I may be wrong Eddie but, that sure looks like my FI pump.
Dave
Eddie914
Nov 4 2006, 08:16 AM
How about this:
911 608 107 00
IronHillRestorations
Nov 4 2006, 09:10 AM
The "early" Bosch fuel pumps for the D-Jet, L-Jet, MFI, and carbs all look like this.
The factory fuel pump location for the 914-6 is the same as the 4's.
Eddie914
Nov 4 2006, 09:36 AM
Did the 914-6 use a pressure regulator?
Early 911 Porsche's used the Hardi pump. Later 911 carb'd models used the 911 608 107 00 pump ... probably also used on the 914-6.
Was this pump internally regulated like the Hardi pump. The 911 608 107 00 pump was plumbed with a return line to the tank.
Eddie
Cap'n Krusty
Nov 4 2006, 10:04 AM
Actually, early 911s used a Bendix pump (really early ones also had a double Solex mechanical pump too. Effectively 3 pumps!. Hardi pumps showed up around the same time as the LWB cars. They had problems, and we sold a lot of replacements. The Bosch EFI pumps looked a lot like the MFI pumps, and the carb pumps as well. IIRC, the discharge ports may vary in size. Best to check the PN. The original 6 pump was under the chassis, below the battery, just like the EFI pump. The Cap'n
