QUOTE(Eddie914 @ Nov 4 2006, 09:39 AM)
Brant,
Do you use a regulator in between the carbs and the return line to the tank to maintain pressure to the fuel rails at 3.5 psi?
Thanks
Eddie
you can plumb the regulator either before or after.
there is a great old thread here somewhere which shows about the 5 different ways you could plumb a system.
my regulator is before the carbs currently.
on my old car it was after the carbs.
with carbs its relatively easy to get "enough" fuel to the bowls and thus the exact correct pressure and volume only has to be "close enough"
close enough to not overwhelm the seat and keep something in the bowls.
with a fuel injection system, I believe it becomes more critical.
I forgot to add that you are going to want to put a fuel pressure guage somewhere close to the carbs. never mount one off of the motor though.. to much vibration.
I've seen this happen.. where the guage was mounted off of the fuel rail and vibrated until it finally cracked where the guage screwed into the rail. BIG fire....
always mount the guage from a chassis point. It will still vibrate a ton, but not as much as the motor.
brant
