QUOTE(76-914 @ Jul 14 2011, 11:58 AM)
QUOTE(ishie @ Jul 13 2011, 11:47 PM)
QUOTE(jwalters @ Nov 4 2006, 08:05 AM)
Hey guys - would someone please give me the measurement for the exhaust head pipe ( oval section). I need the outer spec sizing and the radius section inside. If at all possible, from a set of 1.7 & 2.0 pipes. But either size will help me out considerably. Thanks ---J.
what measurement do you need? i think stylintrucks have that.
my brother bought some parts in there.
Whoa ishie. Are you doing time somewhere? I must commend you on reading back 5.5 yr's, though.
The shorter side of the copper gasket across the "flats" on the outside is 37mm wide. the long side is 43mm, end to end. The inside "flat" is 30mm across to find your radius. Does that help?
