QUOTE(HarveyH @ Nov 4 2006, 11:51 AM)
Brazing is a high temp form of soldering. As you form (and try to melt away) the soldered joint you actually form an alloy of the soldering (brazing) material with the base metal throughout the surface layer of the parent metal. That's why a properly formed joint flows out smoothly over the surface of the parent metal. It's very difficult to get rid of this alloy layer, and it can produce contaminated welds.
Good to hear. I kinda found that out firsthand - "de-brazing" doesn't really work, at least nothing like de-soldering. De-soldering electronics is SOP, but when I tried to de-braze some pieces I only succeeded in removing a fraction of the bronze. And for that, I had to use puffs of compressed air. I ended up using a hacksaw, files, torch, air, and sandpaper to get the piece I wanted.
Why do you want to undo the brazing ? Was it done poorly ? Is it broken ? Brazing isn't as strong as welding, but its still pretty strong.
