OK, Here's my setup;
2.2 (4 cyl) w/ hydraulic lifters and slightly progressive cam for dual dellortos.
Here's what happens;
Car runs great on warm up (warmed up; oil temp about 200 degrees, cyl head temp about 210). Once it is warmed up there is a big flat spot between 2500 & 4000 rpm where anything above 1/2 throttle does nothing but make more noise. My dual carb experience is with old motorcycles (Ducati) and so I have a couple of questions for you experts...
1) Should the feeds (fuel lines) to both carbs be equal length from the "T" after the fuel pump and filter?
2) Since it is an electronic fuel pump should there be a return line back to the tank?
3) On my bikes, I installed nipples in the manifolds for attaching vacuum gauges for syncing. Is that advisable here as well. There are round flat spots on the manifolds that would be the place to do this.
4) Anyone know how to identify which Dellortos I have? Where can I find the part #?
There may be something I have completely missed as well. Any help or abuse would be appreciated! At some point I will probably return the car to FI but that is not an option at this point in time so please don't this inquiry.
