Hi,
I have vertical play in my steering column, so I bought one of the steering column
sleeves. I stripped the column down and it seems like the shim is too small. It
exaclty matches the size of the column itself, but the play appears to be in the
outer edge of the bearing. Can the sleeve be stretched to go over that? I don't
want to destroy anything in the process of "fixing" it! Is there another, semi-
permanent way to fix it?
Thanks,
Jeff
