Ok, so I didn't get around to taking alot of pics of the finished product, but here's a thread I made about my rust repairs (I also did alot more, like trunks, floor pans, firewall, ect.) and they all turned out great.
rustorationMy process was;
1.wirebrush to see what you're dealing with (via grinder... used ALOT of wirebrush wheels)- sometimes I would 'explore' far beyond where I thought the problem was and would find rust begining under perfectly good paint- go searching!
2. chop it if it's cheese (with a grinder wheel)
hint: buy a craftsman grinder- I used three. Paid for one. Gotta love craftsman's return policy
3. shape a piece of sheetmetal for a patch if I had to chop and weld in new material, if not go step four. Shaping sheetmetal is really fun and not as hard as you would expect.
Use screws to hold patches inplace for welding.
4.wirebursh again, shiny as you can get it.
5. burnished slightly lumpy was ok, black spots were not- they didn't pass the screw driver test. I would either continue cleaning black spots with Naval jelly/scraping/brushing/repeat (days at a time on some occasions)- or chop them out if I had to.
6. once all rust was dug out with a bit of force I would apply metal etching/metal prep PPG DX 579 (to clean surfaces) from auto paint supply shop
7. rinse PPG DX 579 off with water and sponge to get rid of acid.
8. Get water out with acetone rags to help immediately dry metal before surface rust could begin again. Hairdryer to bone dry metal helps alot.
9. Paint immediately with ZeroRust spray paint. It's shown to last longer then POR-15 when tested side by side on dock pilings in saltwater.
Sorry I don't have pictures of my trunks and floorboards. They came out awsome and I'm very confident they will last a long time!
