I just captured my settings off of the laptop. Here is a link.
http://wavelen.com/msii_v2p2_jk_110806.zipMy engine is something like a 1.7, but it needs more fuel than stock so it might be a 1911 or some other weird combination. I also have pretty high idle vacuum so there might be a nonstock cam or some engine problem (leaky intake valve?). Regardless these settings should help you get started but will probably be too rich.
I have my CHT calibrated to indicate 1/2 the actual operating temperature so that is why my warmup stops at 140F.
I haven't perfected the cold start settings. Sometimes it takes a second try to get it to start when it's <60 deg outside. I get some mild popping out the exhaust n overrun. It's rich overall and runs around 13:1 most of the time. Gas mileage is in the mid 20s. Could definitely be improved.
Some notes about the setup:
MSII, I forget which firmware. 1 or 2 versions old.
V2.2 board, only mod is to bring +12 to the MSII
1.7L injectors with injector resistors around 6 ohms each, flyback disabled. stock fuel pressure
stock 1.7L CHT and IAT, CHT calibrated to 1/2 value, IAT calibrated normally
tach signal comes off of MSD
AAR for warmup
Tech Edge WBO2
If you need any more info let me know. I think I got most of the critical settings out of MegaTune but I may have missed some.
Good luck!
