QUOTE(Brad Roberts @ Nov 7 2006, 07:47 PM)
I dont know you, but I dont like to see fellow teeners without a job. Can you do fab work? I know of several pro racing teams out of FL that always need decent fab guy's.
What about all these private "time share" small jet places??
I know Arizona is loaded with them.
B
Hi Brad - Thank you for the kind words. I have been trying for sometime to network with Champion in West Palm. Very tight-nit group to say the least. All of my fab work is in aluminum. Basically I rebuild jets. Currently I am building a little single seat ultra-high performance airplane. Tremendous amounts of one-off fabbing for just about the entire airframe. Right now, even tho jobless, I am designing the engine install from the ground-up. (there are no "drop-in's" for this aircraft, everything is one-off) That is actually the easy part for me. What is really super critical is the wing design. It is mine and only mine - no other aircraft in the world has it, and I am well under way to building. I plan to use it to set speed and time to climb records for its size class (under 600 lbs gross). Key is, if I have access to tooling, I can make it. When I lost my job with the coast guard, I lost access to their marvelous machine shop, and am doing everything mostly by hand right now.
Here are a few pics of it.
Everything you see in pics is only mock-up and routing, still a way off from final permanent install.
