rjkavanagh
Nov 7 2006, 08:47 PM
Guys and Gals,
Need some advice. Just made a sample of an insert that should be able to replace the air injector tube going into my 2.0 heads. Is there any reason I shouldn't be able to replace these? Can these be made out of brass instead of steel? Anything I'm missing?
Click to view attachmentThx - Rob
type47
Nov 8 2006, 06:39 AM
i think this is commonly done...
ptravnic
Nov 8 2006, 06:52 AM
I bouoght brass connectors from Home Depot.
type47
Nov 8 2006, 08:15 AM
QUOTE(ptravnic @ Nov 8 2006, 04:52 AM)
... in metric?
Dr Evil
Nov 8 2006, 08:31 AM
If you are interested in plugging the holes you can use valve adjuster screws from a 2.0. They are 10mm IIRC. Just put them in with some high temp lock tite and you are in business.
Cap'n Krusty
Nov 8 2006, 09:23 AM
The design is PERFECT! You've put in the correct sealing surface, the proper threads, and made the top portion look good. What more could you ask for? Well, cheap, maybe, but "cheap" doesn't always mean "right". Great job! The Cap'n
BTW, brass might not be the right material for this.
Dave_Darling
Nov 8 2006, 10:26 AM
How about a way to positively lock them in place? I have heard stories of various plugs backing out over time. I've seen a number of different methods used to keep that from happening, too. The one I remember right now was Mueller's method--he made little tabs that mounted under the engine tin screws in the area (or the manifold nuts?) that simply covered the top of the plug and put a little downward pressure on it.
--DD
rjkavanagh
Nov 8 2006, 02:57 PM
QUOTE(Dave_Darling @ Nov 8 2006, 08:26 AM)
--DD
Great idea Dave thanks. Maybe I'll steal a page out of Dr. Evil's book and see if there's a way to safety wire these somewhere.
-Rob
jsteele22
Nov 8 2006, 04:57 PM
They look very nice as is. One thing to consider (you asked ....) is if you want to be able to install/remove them from an engine inside the car, it might be more convenient to have a longer piece, similar to the original; a little harder to drop out of a socket when you're feeling around for the hole, alignment, etc. It's not unheard of for someone with a '76 to want an air injector system in place for inspection, and then, well, not want it in place for another year or 5.
