QUOTE(George H. @ Nov 9 2006, 07:08 PM)
what is the color on those rockers L96 b?
some one cut of the tops of your front qtrs
Hehe, ya, all the quarters are a bit shorter than stock. shalom.
chalon. whateva!
Not sure on the color, a very pretty color though where its not painted over and still fresh. I think it wasnt a really really popular color though because a porsche purist really frowned when he saw it under the white... i made sure to let him know the PO did all the mods.
QUOTE(Aaron Cox @ Nov 9 2006, 07:14 PM)
it looks like the 2x4's are bowing... (bottom sides..)
Nope, not bowing at all. Some of the 2x4s are warped and I had to pull them into straight as much as i could. I had some difficulties with some.
QUOTE(ChrisNPDrider @ Nov 9 2006, 07:15 PM)
That looks like a cool idea for winter work in the garage
Is it safe? Plan for the worst. You are under the car and have a 4 foot breaker bar turning 300 lb torque and the front caster rolls into the crack then breaks off, will the structure fold and collapse? The cross bracing needs to be strong, and yours looks minimal for side to side flex. Through bolts, nails, screws, or glue or all?
If you *search* threads started by SirAndy, you will find pics of a seriously twisted teener. His had lots of fiberglass body panels too.
Well... it ACTUALLY ROLLS now... with all suspension off of it it is fine now. not like its on ice sliding or anything but it is easy enough to move and goes over the garage cracks ok. I just used 2 1/2 inch screws all around, most joints have multiple from different angles and sides of the wood. It is very sturdy now even moving. before with all the suspension on it, it was actually still solid and didnt wobble at all. but by knocking on each leg i could hear the pressure bearing down. tight with no resonance vs the other cross bracing which still resonated like a regular 2x4.
If i were to build it over again. I would use larger castors, make it a bit shorter and take the time to use wood glue and be a bit more precise with my cuts. I would have done my cross bracing just like the design too vs the improv'd way i ended up doing it.
here are some more pics. I'll put together later full out dimensions and supply list for future builders too.
NOTICE the passenger is off the wood by an inch or so... not sure if this is because my cart is crooked, my garage floor is crooked or the body is crooked. OR if its just because the center tunnel of the car is resting on the 2x4 cross brace in the front instead of on the donuts.
