Have the 914 at a shop to get the carbs and engine tuned up
Had zero compression on drivers side and 125psi on passenger side.
After a valve adjust drivers side compression came up to 60psi...
Adding oil to cylinders didn't change anything
So it's a valve problem, right?
What's causing this?
They're suggesting that they can get it running as best as possible and I drive it for about a month and see if things improve ( Small debris or something in valve area? ), if not, move to the next step to fix.
What do you guys think?
Can a valve job be done to one side? How much is that going to cost?
What about a top end rebuild? What's included in a top end and typically how much?
Also, would an engine with hydraulic lifters be clacking if adjusted to solid lifter specs? I thought the engine had hydraulic lifters but they're saying they're solids -and have adjusted to normal specs with no clacking.
