nein14
Nov 10 2003, 08:47 AM
Has anyone tried to increase the watts on the gauge bulbs? Or changed to the halogen bulbs
Qarl
Nov 10 2003, 09:49 AM
Search the archives... nothing is available unless you want to have one of the gauge places conver to LED for $150 a gauge!
Hi_Fi_Guy
Nov 10 2003, 10:42 AM
I can't believe there isn't a simple pop-in LED bulb conversion like there is for Motorcycle and trailer tail-lights. Is it that difficult to make an LED with a bulb holder that fits the old style?
Qarl
Nov 10 2003, 10:49 AM
The problem is the uncommon base.. the Ba7s.
Also, the gauge lights work of the headlight switch which acts as a dimmer (rheostat).
LED lights cannot handle the fluctuation in voltage and therefore would not work properly.
LED lighs are also highly directional and the gauge backlighting works of the principle of light diffusion. What you end up with is gauges with really bright spots around the edges instead of uniform lighting.
Ideally, it would be nice to find a Ba7s bulb with a different gas (xenon, halogen, etc.) that maybe puts out a whiter light or higher wattage. You could also run into heat issues with halogen!
Finally, you may also run into problems with overloading the wiring with too much wattage!
These are just some of the issues.
fiid
Nov 10 2003, 12:59 PM
I have seen led bulbs that might work for turn signals and stuff, but not for the guages, and from what Carl.... err Karl says it wouldn't work anyway. Which is a great shame - I would love to go all LED.
Has anyone tried using LED trun signal bulbs?
Fiid.
Nov 10 2003, 01:19 PM
whatever you do, don't replace the alternator light bulb
Andy
