My 914 devleloped a problem that it wouldn't shut off when you turned the key off which led me to install a new alternator and regulator because of an article I found on the bird board tech articles. I guess when the diodes go bad in the alternator you get run-on.
So I get the new alternator and regualtor installed, reconnect the battery, turn the key, you hear the stereo kick on but absolutely nothing on the crank...no crank, no idiot lights on the dash....nothing. I went and connected a voltmeter to the positive battery terminal and ground to see if the battery is good and one of the small black wires that goes to the negative side of the coil starts smoking and the compufire inside the distributor also starts smoking. I instantly turn the kill switch.
I'm not sure what happened. I made no other changes but the alternator and regulator--both are new. The new regulator did look different--was told it was a replacement for the OEM--see below.
What do you think???? I'm not to sure what I should do next. My only thoughts are it's the wrong regulator and it somehow has caused this short.
