My car is finally back together!!! Thanks for every ones help!!!
At the jack donuts in the front, my car is 4", and in the back it is 5". The front control arms are almost level with the body (the body side slightly lower and the wheel side slight higher).
There are Bilstein Sports struts, Bilstein 19mm adjustable sway bar, bump steer spacers, and 21mm torsion bars.
Question 1: Should I adjust the control arms so they are level with the ground (or adjust the car using height) at the donuts?
Question 2: Should I adjust the car so the front and back are level at the donuts?
Question 3: How bad will I wear the tires driving them 5 miles to the alignment shop with the camber and caster being off?
Question 4: Where have people gotten their car aligned in San Diego?
Newest Pictures http://www.cassidy-online.com/porsche914/
