QUOTE(GeorgeRud @ Nov 13 2006, 10:44 AM)
Yeah, they smell but they also last about a gazillion miles. A good friend is a Mercedes parts manager, and says the only thing that is a problem with the diesels is that hoses and fittings are drying out and are often NLA on the older cars, so you have to make up your own.
Either way however, the model is a reliable, good design, put together much better with quality parts, than the current cars.
To put into perspective just how well built any mercedes diesel
really is consider this:
There is a new diesel aircraft engine on the market. It is called the Thielert Centurion. This engine is based 100% on a mercedes auto diesel 4 cylinder block and head!!! Basically the same design in production for over 30+ years. It is fully certified and had to pass an unbelievable stress test to reach this goal. Not only this, but
MB SUPPORTED the entire idea from day one!!!! Not a single solitary other auto manufacturer can lay the same claim!!!! (edit: Porsche DID build and certify an aero engine based on the air-cooled six, but has since pulled out of the market and demanded return of all engines in service ,"Mooney's", however, they did all R&D, not an outside source like Thielert)
Reaffirms my experience of pulling MB diesel heads to replace the gasket, and still seeing a perfect cross-hatch. And no head warping or valve distress on ANY engine that averaged 375K miles.
Many people in the experimental aircraft market are pulling turbo sixes out of 300 series sedans and mounting them on their fire-walls. Many of these receive only a freshening up of hoses and gaskets along with a dedicated built reduction drive. Can't beat flying at 200+ MPH with a MINISCULE fuel burn compared to continentals and lycomings -
