Currently I am running original 14" Fuchs on a 914/6 (205/60/14). I want to run 16" rims to get a lower profile on the sidewall and I am trying to get more tire to the road. I drove at my first autocross this year and found that if I hit the gas hard out of corners I would spin the tires and have to backoff let them grab and slowly give it gas. I know my driving skills need ALOT of work but I also want to get the HP to the pavement.
I do not want to stretch or even roll the rear fenders on the car. I have 4-16" x 6" fuchs and 2-16" x 7" rims. I am thinking that a good solution is to have the rear rims converted (made) to 7" rims like the ones Jim Wolcott did on his 3.6L /6 (Excellence October 2006) but leaving the fronts as standard 16" x 6". I am thinking 205's up front and 225"s in the rear.
What problems can you see with this solution? Will they fit without rolling the rear fender lips? What kind of issues will I have by not running all 4 rims the same (6" wide up front and 7" wide in the back)? Does going with taller rims make a big difference on the weight thus making a problem for the brakes?
