QUOTE(Joe Ricard @ Nov 20 2006, 06:15 PM)
So we go to look at the results for this years Nationals.
The guys with slicks got dealt a shitty hand having to run early in very cold temps.
Sure, running in the morning isn't great, but it was far less of an impact than the surface itself was. Brand new asphalt SUCKS for running a large autox event on. Now don't get me wrong, a giant pad of asphalt is darn near a perfect thing for an autox site. But fresh, unscuffed asphalt is terrible. The sand and grit comes up when the sticky tires run over it. Buy the end of the second day, there were quite literally PILES of sand at the outside of the turns on the course. The dissadvantage for the big slicks was that they couldn't get enough grip with all the sand and grit their tires were pulling up off the surface. Even the DOT tired cars had problems with the grit early on.
Now, in a couple of years, when the pad has been nice and worn in, it'll be an autox nirvana. But for now, the DOT AWD cars will gain an upper hand.
If I am able to go I will show up with 2 drivers and new Hoosier R25A or Goodyear R250 tires. and a set of rains.
Can you imagine how much heat you could generate with fence and the engine running? holy crap!
Of course, but there's no way anyone will let you fence the car with the engine running. Off,
maybe. On, not a chance. It's an active heat source, and pretty clearly against the intent, if not the actual letter, of the rules. And leaving the motor on _will_ draw a protest.
-Josh2
