QUOTE(jkeyzer @ Nov 20 2006, 07:49 PM)
Afaik Jeff Bowlsby only makes d-jet harnesses.
For custom applications you might be better off talking to a Subaru tuner. My guess is you would be better off modifying your existing harness youself if you are willing to take the time and do it right. For a niche application like an EJ20 in a 914, there is probably not going to be a "new" harness out there. It makes more sense to adapt the existing harness since most of what you need is already there.
I admit it would be cool to be able to make a new one custom tailored for the 914. You can't imagine how much goes into one of those harnesses though. Everything from the crimp tools to the terminals in each connector is very specialized and hard to find. The connector bodies are reusable from the old harness but the pins aren't. Just buying sufficient quantity of wire with the stock coloring would be VERY expensive as most places force you to buy spools of several hundred feet or more (of each color!) to get custom striping made.
I say, if you cannot do the wiring, don't do the conversion ....the reason being is that unless you get very lucky, you will not find a shop that will touch it...
A local 914'er with a Subaru motor installed by Renegade had his car at a local Subaru "tuner" shop, the car had some minor starter/electrial problems...they wouldn't touch it nor could they recommend a shop that would even look at it....owner had to take the car 600 miles away or something crazy like that....
