I have the old family Chevrolet suburban up for sale. Of course stuff starts to go bad.
First a bolt breaks on the exhaust manifold and then the water pump genades.
The water pump was a quick fix (after getting the wrong pump from the FLAPS) but the exhaust manifold was a PITA.
In GM's wisdom, the Power steering pump needs to come off since the mounting bracket attaches to the exhaust manifold. Of course the power steering pump pulley needs to be removed to unbolt the pump. Of course the pulley is PRESSED onto the pump shaft. Of course a special puller/press is required. I rented the a puller from FLAPS. Of course it pull the pulley just fine, but .... there not press feature to intall the puller!
I'm sure the pulley can be pressed on with a long bolt of the correct pitch.
A 3/8 - 16 bolt threads in about only about 2 turns. Does not seem correct.
Any idea what the correct size/pitch for the puller bolt?
Thanks
Eddie
ps: I'm one happy camper after successufully drilling and removing the broken exhaust mainfold bolt ... of course it was the bolt with the poorest access.
