Britain Smith
Nov 11 2003, 03:36 PM
Check out the custom work this guy did on the rear suspension of his 911.
http://forums.pelicanparts.com/showthread....t=trailing+arms
redshift
Nov 11 2003, 03:45 PM
That guy is a genius.
Hows your arm?
M
ChrisReale
Nov 11 2003, 03:54 PM
He even did a custom see through fire wall....
redshift
Nov 11 2003, 04:01 PM
The way the bars are situated makes the flame front burn away from the driver.
heh
M
airsix
Nov 11 2003, 04:05 PM
I see big problems with this design if left as-is. There does not apear to be ANY latteral support! It looks like the only mount points are an upper mount located to the rear and a lower mount located forward near the original torsion bar tube. (See red arrows).
The yellow arrows indicate how I think everything will shift/flex/bend in a right-hand turn when a side load is applied to the rear suspension.
He could triangulate the suspension frame, but that's where the tranny goes.
-Ben M.
(I am not an engineer, but I play one in my sleep)
JWest
Nov 11 2003, 04:21 PM
My guess is that this is a work in progress, and more structure will be added...
Britain Smith
Nov 11 2003, 04:32 PM
More pics from the bird...
914Timo
Nov 12 2003, 01:06 AM
Ben M, you nailed it. Good pic. That came to my mind first too. I hope we are wrong.
Anton
Nov 12 2003, 01:20 AM
It might work after all. Depends on the strenght of the material used.
To me it looks like a copy of the 993 rear suspension.
I don't think that onyone in their right mind will comment on that design.
Brad Roberts
Nov 12 2003, 02:04 AM
Anton is correct.
It is a very close copy of the 993 rear suspension.
I want to kow what uprights he is using.
B
need4speed
Nov 12 2003, 02:22 PM
Then triangulate on the OUTSIDE of the box. . . ?
