QUOTE(tradisrad @ Nov 21 2006, 07:02 AM)
messix, you got it right the top pic is of the GEX engine the bottom pic is the engine I am going to rebuild.
I took the heads off of the GEX engine (top pic) to compare them to the "factory" heads. I instantly noticed the large ring of carbon at the end of the piston travel (pic 1). I did not notice a ring of carbon on the other piston (pic 2) as the travel went very close to the end of the piston. I am not planning on pulling the rest of the gex engine apart at the time, I was hoping to get some club insight on what may be wrong w/o taking the engine apart. I am going to keep the GEX engine for some future use...
I was thinking that the engine has the wrong crank and that is why the travel stop so far from the head, and therefor giving the low compression. I suppose it could be the wrong pistons on the GEX motor, they have the number "80" stamped on them..
thanks for the replies
-Rob
1. Rotate suspect motor to TDC, you are just speculating with the current picture, it could be that the piston does not travel far enough or like Jake said, the rings could be further down the piston
2. It easy to measure the crank, just measure when the piston is at the top, then rotate to the bottom, use a flat edge across the cylinder top and a scale
