QUOTE(biosurfer1 @ Nov 21 2006, 10:18 AM)
ya, i have the haynes manual, but all it says on that diagram is "Fuse" for both of them...not much help
uhm, no it doesn't!
Page 147:
#91: Fuses for rear window heater, heater blower, gasoline pumpsimply look at the diagram to see which one is which ...
top fuse (towards front of car)- 8A
- get's 12V from Pin 8 at the main harness connector, which goes to Fuse #8 on the main fuse-block
- power is routed to Pin 9 on the engine harness connector, which is unused. (might be used on sport-o-matic models!)
bottom fuse (towards rear of car)- 25A
- get's 12V from Pin 14 at the main harness connector, which goes straight to the battery
- powers relay 52 (top most of the 4, optional) for the rear window heater
- powers relay 75 (2nd from bottom) for the gasoline pump
- powers relay 55 (bottom) for the heater blower
all the info in this post was extracted from the haynes manual pages 147 - 150 ... Andy
PS: the 4th relay (#74, 2nd from top) is for the power supply and is *not* connected to any of the two fuses ...
