groot
Nov 21 2006, 11:17 AM
Finally, I'm actually constructing my rear suspension. This one's been in the works for a long time. I've had the parts, but lacked the mill/TIG time to make it happen. So, I'm starting with the 914 trailing arm instead of the 944 trailing arm (need the TIG for that one since it's alum).
Some background, the SCCA production rules state this under "Unrestricted Suspensions: Suspension Control":
2. Suspension pickup points on the chassis or structure may be relocated and/or reinforced. If such points are relocated to the driver/passenger/trunk compartments, such points and attendant suspension components shall be covered with metal panels.
3. The manufacturer’s original system of suspension, e.g., live axle, swing axle, MacPherson strut, A-arm, etc., shall be retained. The wheelbase of the vehicle shall not be changed or relocated in a fore/aft direction.
4. Suspension bushings are unrestricted. Adjustable spherical bearings or rod ends are permitted on all suspension components.
5. Any anti-roll bar, camber compensating device, panhard rod, watts linkage, and/or other suspension stabilizer is permitted. Attachment points of such components are unrestricted.
So, I can move pickup points, I have to run a semi-trailing arm suspension, but I can add a toe link.
The basic idea is that I can get the camber gain I want by playing with the location of the pickup points of the trailing arm to the chassis, but replacing the bulky semi-trailing arm with rod ends on tubes allowing easy control of static alignment settings. Simple geometry.... But, you're stuck with a crappy toe curve.
What suspension gives an excellent toe curve???? A real trailing arm (no toe change). So, allow the rear suspension knuckle to pivot in toe, but control that toe with an additional link (attached to the chassis in such a way that it mimics a trailing arm). This was the brainstorm that hit me one day.
I gathered all the parts last winter, but spent so much time in AZ for work I didn't get to do the work before the racing season crept up on me.
Here's the work I did this morning. That rectangle stock sticking out will be where I attach my toe link. The semi-trailing arm links will mount on the top and bottom of the knuckle (bearing carrier).
brant
Nov 21 2006, 11:30 AM
this is going to be a great thread!
URY914
Nov 21 2006, 12:55 PM
Brad Roberts
Nov 21 2006, 01:00 PM
We need to go over and figure out exactly how Kinematic toe works on the Boxsters/993's/996's
Let me show you a little secret:
928's were the first to have Kinematic toe (little to no toe gain in bump)
I'll find a better picture when I get home. This tube chassis has the 928 arms on it.
B
Brett W
Nov 21 2006, 01:03 PM
Guys, Kevin and I have beat this one to death. One thing that we disagree on is, the interpretation of the rules. I say run something like the Sheridan rear suspension so you don't have to deal with the roll center movements every time you adjust the suspension settings. The rules say you can't add any extra pivot points. I don't see any extra active pivot points.
One of the benefits of Kevin's setup is he can force a favorable toe change which unfortunately on our suspension designs is non existent. Our cars will toe when lowered radically. While decent on the street it doesn't provide good suspension control on a race car.
How much rear suspension travel are you planning in your setup?
Brad Roberts
Nov 21 2006, 01:05 PM
I have been of the belief that you could "fake" the semi trailing arm and do some kind of inboard heim joint control arms that stress the tranny (like an open wheeled car) use the semi arm to make it look like you are using it.
Roger Sheridan does this with an empty strut tube in the front of his car and a Penske shock mounted in-board of the empty strut tube. The rules call for it to be in place but he couldnt get a decent shock for the strut.
B
Brad Roberts
Nov 21 2006, 01:09 PM
Not sure what your bottom arrow is pointing too, but Roger only runs one toe adjustment rod. The entire wheel carrier pivots on that lower spherical bearing.
His car passes SCCA GT2 rules with flying colors. Jim Blakewells rear arms are VERY similar to Rogers and the ones we worked on back in 1996.
B
Brett W
Nov 21 2006, 01:50 PM
As far as the Boxster stuff goes, it uses a rear strut suspension. Its elastokinematics move the rear suspension to toe in under braking and over time the bushings will wear and create the same problem under lateral force.
The 928 has the same issue. It requires bushing compliance which is fine on a street car, but a race car requires a higher degree of suspension control.
Sheridan runs two toe adjustment rods on his car. Check this next picture notice the upper and lower rods. Sheridans car is grandfathered in as is Blakewell's car. SCCA put a change in the rules that require the shock/strut to run inside the spring. SO all further cars built after, I think 1997 (I don't have my rule book here) ahve to abide to the new rules. Also newer cars built after a certain date can run any type of rear suspension, in GT. But back to Production racing.
When you adjust our rear suspensions you have to deal with moving the roll centers around. It will change the handling every time you adjust it. Now Finch likes to set the rear suspension where it needs to be and re-weld the stock trailing arms into position. Other than dealing with compliance in the rear suspension arms this is not a bad way to go. I would build a new arm all together and set it where you need to be. Problem with this approach is you are pretty much fixed as far as suspension settings go. Having adjustment is good which keeps bringing me back to Sheridan's rear suspension design.
maf914
Nov 21 2006, 02:58 PM
What is he doing with the shift rod where it enters the side shift console at the tranny? Is that some sort of universal joint?
The shift linkage discussion on another thread made me notice this.
Brad Roberts
Nov 21 2006, 03:26 PM
He is running a seriously modified Vellios shift kit on a 915. The Vellios kit utilized a stock 914/901 plastic cover for the shift console.
Roger's arms versus Finch method:
The Finch method is much easier and you will find it more in production cars than you will the Roger style of arm.
Something else of note: learn to drive. All this is great, but I have found that the pro's rarely know SHIT about the suspension. They can drive BRICKS if need be. Bontempi will school your ass right now.. with none of this trick shit..LOL He may go faster with this good stuff (I installed roller bearings in his car a fw years back) but I really dont think all this is needed in a production car. It just doesnt build the speed or G forces that say Blakewells or Rogers car can generate.
I disagree about the "compliant" rear suspension stuff on kinematic toe. I havent ran a GT3Cup car or GT3RSR with "rubber" in the suspenion (ever) Pretty easy to see what the suspension does on the alignment rack by loading and unloading the chassis. Physically watching it, the toe doesnt change front or rear. I *beleive* the toe does change in the rubber cars, but no where near that of the semi rear control arm of the 914.
B
groot
Nov 21 2006, 03:50 PM
Ok, just got back from the dentist (root canal), so I now can get back to work.....
Not to hijack my own thread... but.... Production racing is more about engine than either the driver or the suspension. The next most important thing is the driver.... then it's suspension setup more than design.
I won't list my driving credentials because I think it's a silly discussion. Who cares? I've always said that if I get to the point that I (as a driver) am not getting the most out of my car, I will put someone in it who can.
I am doing this because I want to and it may make my car a bit more driveable and a bit easier on the rear tires. This is why I'm running production in the first place. Finch's car runs on a pretty close to stock suspension and it's very fast. I was inspired by Finch's legal GT2 944, however.
Now, back to the discussion at hand. Sheridan's setup is great for setting STATIC toe. It does nothing for DYNAMIC toe.... (the curve). His setup suffers the same toe curve issue on all semi-trailing arm suspensions. My idea is to control toe dynamically.... it's not a new idea. I've heard of people using compliant bushings and a toe link to deflect them to achieve a similiar results. Sheridan could have taken the next step and still be legal in GT.
Brett-I've come around on the legality of that Sheridan setup....actually a discussion with Finch helped me see the light
Now, back to
Brad Roberts
Nov 21 2006, 05:55 PM
Roger gave up on SCCA GT2 ages ago. I dont think he ever actually ran an SCCA race.
You are correct. Figure out a way to control toe throughout the suspension range and stay within the rules.
Should be interesting to say the least.
B
groot
Nov 21 2006, 07:25 PM
A little progress.....
Maybe this will help some visualize my project. And... no, I won't cantilever the rod ends, I need to fire up the chop saw to make the other side of the bracket and that would wake the boy.
Picture 2 tubes coming from the upper portion of the knuckle and the same on the bottom. One tube from the top goes straight forward and mates up with one tube from the bottom on the chassis. And, the other two tubes mate up inboard of that at a different point on the chassis. Where these points are located define the camber curve. Then, there's that lonely tube that comes off of the rectangular tubing... that's the toe control link. That mates up at a different point on the chassis and it's location defines the toe curve.
This is still a semi-trailing arm suspension.
bam914
Nov 21 2006, 07:51 PM
Kevin, How fast are you going through rear tires? Are you running a Lincoln locker? AKA a welded diff. When I had my EP car I had six tires. 4 430 GY's and 2 600 GY's. I ran the soft one for qualifing and the 600's went on the left for the race. I had 6 sprint races, one Solo I, a PCA driver ed and the SARRC championship, which I won, on the those tires. They still had just less then half the tread on them. Just wondering. I had no crazy rear setup. Just the stock attachment point. -3/4 degree camber and 0 toe and an open diff.
groot
Nov 21 2006, 08:02 PM
Hey, Blake,
I'm not really wearing through the rears any faster, but during a race I put much more heat in the rear and the car gets loose after about 6 hard laps. It's enough to force me to consider going to a split compound or smaller tire size in the front. This project is just to get the rear suspension working as well as I can get it to work. From here, I'll start trying split compounds or sizes to get the balance right over the entire race.
I've been running a open diff, too.
Brad Roberts
Nov 22 2006, 12:58 AM
What tire pressures Kevin? and who's tires?
I'm limited to Goodyear experience with the production cars.
We did a TON of tire testing with Goodyear after they moved the plant from the USA. We still have tires with no compound numbers on them that they gave us after testing. They *used* to give us tires before each National race with no compound markings. Kinda cool.
B
Brett W
Nov 22 2006, 01:54 AM
QUOTE(Brad Roberts @ Nov 21 2006, 01:26 PM)
B
I have to agree, seat time is the most important thing to a successful driver.
The GT3 uses a completely different suspension than the boxsters and Cayman. You should not see this compliance. It is not necessary. The GT3 is designed as a race car from the beginning. Hans didn't have to worry about grandma trail braking her GT3 Cup car turning into the church parking lot. But when she lift throttles mid corner he can't have the tail of her shiney Boxster convertible cruising around on her when she is headed to the grocery store. All production cars are designed with toe in under braking for stability. The 928 relied on elastokinematic deflection to create its toe in under braking. The front dog leg moved back and the rear dog bone actually bent under braking. Race cars do not typically have compliance designed in. It makes the cars harder to drive.
Kevin, I agree Sheridan's setup is for static settings only. Why he didn't design in a toe link, I don't know. Maybe Bertold could tell us if we knew where to find him.
Production is more for drivers where GT is more for builders. Kinda like the Mod class in autocross.
groot
Nov 22 2006, 06:23 AM
I share my progress on my rear suspension and everyone tells me to learn to drive. ZZZZZZZZZzzzzzzzzzzzzzzzzzzzzzz
Brett, prod is more a builders class than IT, so it all depends on your perspective.
Brad, I've been running 430s. I haven't run 600s yet, but may resort to that in the rear next season. The weight this car runs at, I find it hard to believe a 600 compound is really the answer, but I'll try it. I've been running a 1.5-2 psi split to keep the rears under the car. Starting pressure varies between 18 and 22 psi depending on temperature. I had some good conversations with Loshak about some other things to try, like starting at a higher initial pressure.
I wish I had a tire testing deal on the race car, but for now I just order 100 at a time for work and chew them up on a daily basis..... Our team of 4 guys ate up 32 tires in one day a month ago....
Brad Roberts
Nov 22 2006, 12:06 PM
Hang in there Kevin! My "learn" to drive goes out to those watching at home. All too many times I come across people who spend more time "engineering" and not driving. It wasnt directed AT you. We have a LOT of people who "watch" these threads.
Thanks for the info on the tires. Unless something changed with Goodyear, I could never see a 914 on west coast tracks needing a 600. "Maybe" Willow Springs at 120deg track temp and mostly FAST right hand turns, but we have always dialed that out with tire pressure splits.
Burning down the rear tires.. huh?? can you give me tire temp examples from notes?.. if tyou do have it.. include track temp/air temp/ and actual track you ran that day.
B
Brad Roberts
Nov 22 2006, 12:10 PM
Then why are 3/4 of the part numbers the same? (early 99-05 GT3) and early 97-04 986/996
The alignments are performed the same
Kinematic Toe is done the same way
Completely different? No. Different? yes.. but not by much
B
groot
Nov 22 2006, 01:02 PM
Maybe not "burning" the rears, but definitely getting them greasy in the middle of a long run. I usually start out running a slightly higher slip angle in the rear and as the tires get hot, that slip angle gets higher and higher.
I'm usually alone at the track, so I'm not religous about getting tire temps. My racing buddies are running SMs in regionals.
But, there's usually a 10-20 degree difference after a long run between the fronts (170-180) and the rears (190-205). After a short run, they're pretty close.
So, in my mind, once I get the toe curve under control, I'll re-assess the situation. I do believe a crappy toe curve builds heat more quickly.
After that, I'll decide to either go down a tire size in front (the 8") or change a compound at one end of the car. I've heard the R250 compound is not a great choice, but I don't have direct experience.
Brett W
Nov 22 2006, 01:18 PM
My bad I was under the impression the GT3 used a weird 5 link setup where the boxster used the strut setup. See what happens when I only get to work on old stuff. Plus there are no Gt3s running in HSR, yet (that I get to work on).
Kevin this tire data may not matter to you, but we run a 430 on our RX7. For a long time we ran the EP tire before we went to a wider tire. We would see 175 at the center of the outside rear tires. I will usually start pressures at 20-24 depending on conditions and come out with pressures close to 30-31 by the end of a 30min test session. The car weighs 2200 and change, so you should take that into account. The driver doesn't say anything about the tires going away towards the end of the situation.
Brad Roberts
Nov 22 2006, 03:32 PM
Kevin,
we used 250's for qualifying if we had more than 4 people show up for our class.
made some calls:
The west coast tracks (Laguna & Sears.. very similar in elevation change to Mid Ohio/technical) the cars performed best at 27-28 hot on R430's from a year ago. This is a race winner who qualifies on the poll in a legal car against 5-6 other Fp cars who show up. Multi time National winner.
B
Thorshammer
Nov 23 2006, 02:18 PM
Okay boys!
I have heard some of the limited prep guys running the cantelever slick at higher pressures than normal, I can't run them that high. My normal starting pressure is near 17lbs which gives me a 24.5-27 psi hot pressure. As for qualifying with 250's. Good call, my budget does not allow for that. I have been using tire warmers and qualifying on the 430's. As for running 600's in the rear. I don't think thats the way to go. But you have to do what you have to do. I think Kevin is driving the car very well, and very hadr trying to make up for his lack of power. He ran 139's? at MO and I ran 1:36's (I think) and I probably had 30 or better hp on him. Once he gets his new MOTOR. He'll be fine, btu I do agree that the rear triling arms can be improved. All the rest of us are doing is working with the existing trailing arm, Where as Kevin is attempting to correct some deficiencies (sp) with all semi trailing arm designs, adn apply them to the 914 within the constraints of the rules.
BTW Kevin, Sargis car has a similar type deformable bushing and toe link for his trailing arm swingaxle spitfire. Many of the front running spits have now developed something similar. It has been through two protests and been declared legal, so I think you are fine.
I don't totally agree with you in one way, I really don't think EP is just a HP class, I think both of us can run at or near the front with the right engine and chassis combo. With the way my car is set up now, I think I can run with Pratt or any of those guys. Lowshaks Honda IS fast. it will be interesting what my car will be able to do against him with the new motor. Building a Runoffs only motor.
I think if you have yours (come on JAKE buddy, I think I can, I think I can) (just kidding, I know your working hard at it) you will have a good shot.
I really think one of the only drawbacks to what we have is getting fresh air to the carbs/airbox, legally.
Erik Madsen
Eric_Shea
Nov 24 2006, 03:39 PM
Great thread Kevin. This will be great to watch.
Erik and I had a talk about control arms last month. I'll have a nice kit or complete arm for the more plebian enthusiast based around the stock unit and some of the things we discussed.
Eric
groot
Nov 24 2006, 03:55 PM
Erik, thanks, but I didn't get into the 1:39s, I only managed a high 1:40.
Updates... Here's how I'm mounting the rod ends to the trailing arm. I've got to do this on the bottom of the knuckle, too. It's beefy, I know. The 2nd generation of this suspension will use alum 944 knuckles.
Brett W
Nov 24 2006, 04:50 PM
Have you run an FEA on this setup?
groot
Nov 24 2006, 07:06 PM
Nope... if I had, it surely would have been much less beefy.
GTPatrick
Nov 24 2006, 07:21 PM
Food for thought on this subject folks. Don't know if the following have been previously discussed or not but here goes.
1) Has anyone given some thought to adapting a Porsche 911 rear trailing arm suspension to a 914 ? Maybe one from a competitive/racing 911 car ? Cost may be high but some of the ideas in this thread ain't cheap either .
2) What about a totally new handbuilt design that completely replaces the 914 trailing suspension pieces ? Maybe even 1 that uses some of the components from either a 911 or possibly a 914 ? Again costs and time for development rears its ugly head here too.
With all of these design modifications, won't some of them possibly have a builtin design flaw/weakness that the original suspension design did not either address or was ever previously conceived of ???
Just some food for thought here. Some of your ideas seem to be really neat but why not take it one step further ???
GTPatrick.
Thorshammer
Nov 24 2006, 11:40 PM
GTP,
The SCCA Rules have some very strong limitations. Most of us can and would change the entire design, but we must keep within the rule structure. IE Semi trailing arm. One problem using the 911 arm is the position of the engine and where the 911 arm would need to attach. Remember the 911 arms attach in an area where the trans width is, we must attach them to an area where the engine width is. This makes the car way too wide when using 911 arms. So this probably won't work.
Also Kevin is trying to change his camber gain while minimizing toe change. which is critical for racing cars. changes in toe which are significant are not good. While an amount of camber gain is very good. We actually would like just a touch more than we have now. And without the amount of toe change.
We appreciate your comments about this. Keep em coming.
Erik
GTPatrick
Nov 25 2006, 07:13 PM
Erik, . . . .
I thought that it would be a rather neat idea for a street/track car ro be used in AutoX , PCA DE events or some other track event. I figured that the SCCA wouldn't go for it.
But if someone had enough $$$ and a lot of time on their hands iat could give some of those rice burner cars a good run for their money.
Brad Roberts
Nov 26 2006, 01:21 AM
Ha ha.. I have a friend who thinkgs along the same lines I do! We discussed replacing the whole damn thing..
Scary how close the Boxtser stuff fits under a 914. Cured all toe gian issues and camber gain!!
Not legal
B
Brett W
Nov 26 2006, 01:23 AM
If you don't have to, scrap the semi trailing arms and go to a true upper and lower control arm setup. That is what I am working on. Super production here we come.
groot
Nov 26 2006, 07:28 AM
Every suspension design has it's compromises... even a double A-arm setup. I believe it's a matter of optimizing whichever design you have or switching to one that accomodates your needs.
groot
Nov 26 2006, 12:36 PM
Left wheel end complete.
Tomorrow I'm off to AZ for work for 2 weeks, so no more progess until I get back.
brant
Nov 26 2006, 01:34 PM
kevin before you leave town for work...
can you hold it up to the chassis in place for those of us that are extremely visual?
brant
roadster fan
Nov 26 2006, 01:53 PM
If you look at the third picture, I think it mounts in that orientation on the drivers side (we are looking from front looking towards back of car). It has an upper and lower link, and the toe link is the mount furthest inboard (left on picture).
the upper and lower links will run to traditional 914 pickup points and the toe link will run to an advantageous position on the chassis to minimize changes.
Hope I got it right........hope you can visualize it with that explanation. If not I guess we will have to wait for Kevin to return from AZ to correct me.
Jim
groot
Nov 26 2006, 01:59 PM
You got it, Jim.... except for the part about using traditional pickup points. If I used the original points, I'd be stuck with the camber gain of the original design.
I was thinking about how to hold it up to show the idea better, but it will definitely make more sense when I have some tubes attached... and all my tubing is still full length.
Series9
Nov 26 2006, 02:04 PM
QUOTE(Brad Roberts @ Nov 26 2006, 12:21 AM)
I'm planning on that exact conversion on my next personal project.
byndbad914
Nov 27 2006, 01:59 PM
Kevin, are you running the toe link all the way forward? Any reason why not inboard? Here is a shot of my 5-link rear I just finished a few months ago, I used two lower arms inboard to set toe, the top will set camber (mild track changes won't throw off the other dims).
Click to view attachmentClick to view attachmentbased on this drawing I found online at one of those supsension software sites
Click to view attachmentDon't quote me that this is the best design ever or anything like that - I just got the car fired up yesterday, so now I have to weld in the seats and get it all scaled and finally get a real alignment on this car and check all the bumpsteer. Visually (tho' how accurate is that, right???) I see no bump whatsoever through about 5" of motion and since I will only see maybe 2" of that, I suspect it will be really solid.
groot
Nov 27 2006, 05:39 PM
Good work!!!
I'm bound by the rule book and have to maintain my trailing arm design, so a setup like that isn't part of my plan. I am running my toe link forward.
It will be more clear once I get the chassis side complete... but that will have to wait until I get back home.... Fun in the sun!!!!!
race914
Nov 28 2006, 05:45 PM
Brad Roberts
Nov 28 2006, 06:16 PM
Ha ha Greg!
I just tracked his site down again over this past weekend to see what he was working on!
The guy is amazing. More talent than I will ever have
B
edgetoo
Dec 2 2006, 08:47 PM
QUOTE(Brad Roberts @ Nov 28 2006, 04:16 PM)
Ha ha Greg!
B
Hi Kevin,
I am the current owner of Blakes' car and motor.
Last season we sat down and tried to optimise the setup. Rear rideheight was
lowered about 2 in. (there is now a signiffant dent in the x-pipe above the axel
and the cross-over pipe under the bell housing is worn thin.)
The front and rear have been bump steered and cross weighted. The rear camber
is about as Blake ran it with minimum toe in and toe change. (trailing arm bushes
are by CFW as are the camber plates.) (Front struts are by CFW) Rear Piviots
points are stock.) Motor has about 12 races on it.
Net Results were 2 poles under the lap record, 1 lap record, and 1 win.
(I'll discuss the Trans- HE- on the other thread)
Ed Givler
ChrisFoley
Dec 5 2006, 04:34 PM
QUOTE(edgetoo @ Dec 2 2006, 09:47 PM)
(trailing arm bushes are by CFW as are the camber plates.) (Front struts are by CFW)
Ed Givler
Hmm, CFW. That would be
Chris Foley Welding I guess.
edgetoo
Dec 6 2006, 12:46 PM
picky, picky!!
Thank goodness that Chris' fabrication is much better than my spelling!
Ed
