terrymason
Nov 21 2006, 02:49 PM
Looks like my 4 lug fuchs had some stick on wheel weights put on the outside at one point
They were removed, but the glue / adhesive that was used is still on there. I was able to get alot of it off using a razor blade, but couldn't get the last 25% off. I tried wd40, and even alittle brake cleaner, but it didn't come off.
Anyone have an idea that won't kill my rim?
Bartlett 914
Nov 21 2006, 03:01 PM
There are probably a lot things tha will work. I use a solvent cleaner made by Claire. I'm sure you can find it unter some other name. It contains trichlorethylene (79-01-6). It evaporates quickly so you still need to work it a little and often but it is O.K. for sticky adhesive residue.
So.Cal.914
Nov 21 2006, 03:41 PM
I have used this stuff called Goof-Off, put it in a rag and hold it on for a minute or
so. Also theres a product called Goo Gone that works ok.
Brad Roberts
Nov 21 2006, 03:57 PM
SoCal nailed it.
Goof-Off or Goo Gone
SOAK IT.. soak it good with the stuff. It will wipe right off and you will find lots of uses for it later.
We use this all over the factory Porsche race cars to get rubber off the graphics and to clean the wheel weight glue off (we tape the weights on)
B
Pat Garvey
Nov 21 2006, 08:02 PM
I'm in for Goo Gone. Provided the top layer is even slightly porous, the GG will seep through & eliminate the adhesive qualities below. Be patient & liberal with GG. Let it soak for 30 minutes & you'll be able to wipe the whole mess right off.
Put away that razor blade, before you metal!
terrymason
Nov 21 2006, 10:14 PM
I'll give it a try this weekend. Thanks for the tips guys. I actually have some goof off in the garage - hadn't thought to use it.
Cap'n Krusty
Nov 21 2006, 10:33 PM
We used both Goof Off and Goo Gone side by side on a Mercedes hood pad. Goof Off won hands down. The Cap'n
Michael N
Nov 21 2006, 11:16 PM
Goo Gone is citrus based and works well but not too harsh.
Goof Off is toluene based.
