I was playing with the spec boxsters front wheels today. I have 3 full sets of rims and tires for the thing. 2 sets for Track and 1 set for AX. All are stock rims (these things are CHEAP). Fronts are 17x7 and the rears are 17x8.5's.
I have 245/45/17's on front and 275/40/17's rear. No rubbing. These are Kumho Victoracers. I'm using these to dial in the suspension since they wear pretty well. I have a set of Hoosier R6's on the way to try out as well in 245/40/17's and 275/4017's. I want to try a little less sidewall on the front since the 245's are pinched a little on the rims (looks exactly the same as a 205/50/15 on a 2.0 Fuch).
For kicks I put on some rear wheels that have used 255/40/17's. Since they are not as tall as the 245/45's they fit in the wheel well better. And they are about 3/4's of an inch wider in contact patch and over 1 inch wider on the shoulder when you roll it over. And with the 8.5 inch rim, the sidewalls are straight up, not pinched in.
Since the 255's fit pretty well (I may need a 5mm spacer to clear the spring collar under load, don't know yet) but they only come in the Victoracer sizes and not in V710's or Hoosiers, would the corresponding gain in footprint offset the compound improvements that the V710's or Hoosiers provide? Or should I try mounting a set of 245's on the 8.5 rims and play with that?
My thoughts are that the compounds make a bigger difference than 3/4 of an inch, but on the other hand, if I want to stay budget I could get 2 more rear wheels and just go with 2 sets of rims with Victoracers for track and AX.
What do you guys think?
Here's some interesting reading from Michelin's engineers regarding the Pilot Sport Cups and sidewall flex and pressures:
Michelin Tire Engineering Presentation
Thanks,
Bill P.
