QUOTE(SirAndy @ Nov 21 2006, 08:23 PM)
QUOTE(kconway @ Nov 21 2006, 08:07 PM)
Did I goof this up?
did you roll the car several feet back/forth afterwards?
did you zip-tie the top of the springs to make sure they're setaed correctly on the top?
did you doublecheck that the springs are setaed correctly on the perch?
how long are the springs?
how many notches do the bilstein's have? the usual 5?
did you get the full thread engagement on the top?
if you answered yes to all questions and the springs a stock length, you'll need to drop the perches lower ...
Andy
Haven't moved the car since.
I used a spring compressor and ensured the spring seated in the top and bottom OEM perch and top.
The springs are 140lb weltmeisters, considerably shorter than what I removed which was OEM.
I think there were 7 positions on the shock, I'm at the 3rd down.
I did get full thread engagement on the top.
