I just installed my front Oil Cooler in my 914/6 conversion project and thought I would post some pictures.
Here's one of the brackets that I fabricated from 3/4" aluminum angle - most of the "machining" done with a sawsall.
Two of the brackets hold the cooler in place and provide a frame for the ducting - to be added after I have the car running.
Here are two detail photos showing the shock mounting. I use standard isolators at the bottom and a piece of aircraft silicone baffle seal (which will also be used to block airflow from bypassing the cooler) at the top.
