Allan
Nov 22 2006, 01:18 PM
Currently I have a facet pump with some wierd Sparco? press and click pressure regulator that seems to fluctuate between 2 and 6 psi.
Can anyone recommend a good pump and regulator set-up that's reliable and will give me a constant 3-4 psi?
Aaron Cox
Nov 22 2006, 01:19 PM
CBperformance internaly regulated rotary pump.
solved my fluctuation issues... chuck the facet and dial regulator!
Aaron Cox
Nov 22 2006, 01:20 PM
Allan
Nov 22 2006, 01:25 PM
So, no need for a regulator with the rotary?
Aaron Cox
Nov 22 2006, 01:27 PM
weed da text....
internally regulated to 3.5
none required. and you dont get to hear it... its that quiet
BTW - i think steve wood is gonna need my tools soon...
AA
echocanyons
Nov 22 2006, 02:50 PM
A peirburg pump and PMO's own regulator is what is usually recomended.
GeorgeRud
Nov 22 2006, 02:54 PM
The CB pump appears to be the Pierburg one. Not only does it work well, but it is small and can easily be placed by the steering rack to relocate the pump up front.
You can also order them through MidAmerica (the old Tweeks VW site).
