nyum96
Nov 11 2003, 09:36 PM
I'm at the end of customizing. Last night I saw some Hella rear fogs (Porsche 911) and thought that would look cool. You know, to make my car stand out even more in the community. I've seen some pictures w/the fog on the rear (where 914 script is located on left side) but is this the right place or does it mount lower towards the rear valance. Just a thought.
Next, what about wiring the thing. Comments and suggestions are welcomed.
Barry
Kargeek
Nov 11 2003, 10:05 PM
Barry, The factory location for the 914 fog light I believe was on the rear panel just next to the left tailight. I have a european wiring harness in my car and there is an extra white with green striped wire stubbed for it. The 914 fog light may not the same as used on the 911. You could copy the 911 location. Use any fog lamp and mount where you like- to switch it seperate from your running lights will require that you run a new wire and maybe switch it with your front fogs.
Dave H
