pete-stevers
Nov 23 2006, 11:31 PM
i just took apart a front sc suspension....and the torsion bars are rusted on one side...are they usable? or is it recomended to get new ones...can i go heavier, (they have thirty splines).
second question... any one have a matching control arm....as you can see...one is shot
swood
Nov 23 2006, 11:41 PM
Hard to tell, doesn't look too bad. But if you're getting wear or pitting from rust, it's a weak spot prone to failure. You should be able to find some replacements fairly easy, I did. Or just upgrade to a new aftermarket set.
pete-stevers
Nov 24 2006, 11:54 AM
where does one find aftermarket torsion bars?? there is a small nick on one of them from the damaged control arm.
and which ones will be similar or stiffer to the ones pictured
thanks
Krieger
Nov 24 2006, 12:22 PM
Try pelicanparts.com or ottosvenice.com or gprparts.com These are great resources that have been around for years.
swood
Nov 24 2006, 02:21 PM
I just meant a new set, not new OEM bars. I recently was at Ottos looking for a used replacement pair and he didn't have any. I posted a WTB ad for them here and got a few responses.
pete-stevers
Nov 24 2006, 05:14 PM
i contacted ottos....to see if "he" has any torsion bars....
Aaron Cox
Nov 24 2006, 06:37 PM
21mm weltmeister or sway away bars are a nice stiff ness on the streeeeet
Jeroen
Nov 25 2006, 10:43 AM
Steve, you can order your torsionbars from Tarret as well...
Joe Bob
Nov 25 2006, 10:56 AM
When I redid my SC for track duty, I found some amazing deals on used stuff that people buy and don't use.....t-bars, shocks and adjustable springs plates.....I didn't have to buy anything new and got them for 50% off the retail prices.
Post a WTB ad in the 911 section over at Pelican and join rennlist for a couple of weeks.
