Grelber
Nov 24 2006, 10:17 AM
Ok, my headlights worked fine a month ago. Last night I was driving home, hit the high beams, and the headlights went out. Switched back to low beams and they work fine (on low). Hit the high beams again, and they didn't go out, but the low beams stayed on.
Now, the high beams don't come on, and every 5th or 6th time I hit the switch, the headlights completely go out.
Grounds? (wouild [probably affect both high and low beams) Switch? Relay? Wiring?
Help me, Mr. Wizard.............
TheCabinetmaker
Nov 24 2006, 10:33 AM
headlight relay bad.
Grelber
Nov 24 2006, 12:10 PM
Is the headlight relay on the fuse/relay board? I know where the headlight motor relays are.
SLITS
Nov 24 2006, 12:11 PM
QUOTE(Grelber @ Nov 24 2006, 10:10 AM)
Yep, fuse panel!
Grelber
Nov 24 2006, 12:29 PM
Thanks. One last question, can I get relays at my FLAPS, or do I need to go to PP or other?
Triaddave
Nov 24 2006, 12:35 PM
on my 75 car i had the same problem. it was the switch. try turning the lights on and wiggle the knob. the switch for the 75 car is like $480.00 new. the 74 and 76 switch does not fit the 75 car...
Grelber
Nov 24 2006, 12:37 PM
The switch on the dash, or the high/low stem on the column?
SLITS
Nov 24 2006, 12:41 PM
From Pelican Parts site
Headlight RelayHeadlamp Relay, 914 1.7/1.8/2.0 (1970-76), Each
Brand: Meyle [Photo]
111-941-583-M155 $29.00
Triaddave
Nov 24 2006, 12:45 PM
the switch on the dash is where my probley was.
ps, at the cost i still have'nt replaced it. thank gosh the fogs work, and i try not to drive in the dark
Grelber
Nov 24 2006, 01:34 PM
Thanks. There's a couple on ebay right now. I'll see if I can grab one of them. (Both are the right years as well).
dinomium
Nov 24 2006, 03:40 PM
QUOTE(Triaddave @ Nov 24 2006, 10:45 AM)
There is a how to repair article on PP
JPB
Nov 24 2006, 07:20 PM
The samba has a switch also for like $35 I think.
