QUOTE(mrhurtalot @ Nov 24 2006, 03:32 PM)
hmm well i figured i could poke my dremel aroudn some.
i dont know.
what other options do i really have?
As I see it, you have no choice other than to repair it properly. I have limited Detroit Iron steering column experience, but it's a complicated job that even my neighbor, the Ford specialist, doesn't like doing. I'm sure it's a tilt wheel, making it even more fun. If it's just the tumbler part, there are relatively simple techniques for removing it, and you may be able to order a new one keyed to match. Googling the problem suggests there's a hole below the tumbler. Turning the key to the run position, you push a small punch into the hole and depress the locking pin, then just pull the tumbler out. If the key won't turn, you either have a bad key, a bad tumbler, or a bad steering column lock. If your key is really worn out, maybe you should buy a new key from the dealer. They should be able to access the information to get it right. If that fixes it, get a second key made and put the first one away. If it's the switch portion, it's likely to be difficult. If it's the steering lock or lock housing, it's gonna be even worse. I do a lot of 'em on Volvos and BMWs, and I hate every one I have to do. The Cap'n
