Pardon my ignorance, but am I correct in assuming "the collector" is the piece that combines three pipes into one?
This O2 sensor is going to be used for feedback to a Megasquirt EFI system.
The EGT is a neat idea. I've used them on aircraft but have never seen one on a car. Can you point me at someone who makes the probes and gauges.
QUOTE(Twystd1 @ Nov 24 2006, 01:00 PM)
IMnonHO,
Anywhere within 6 inches from the collector going out the back of the car.
(I like in the collector or very close if possible)
It should not be installed BEFORE the collector or less than 12 inches from the end of the exhaust if possible.
(unless you want to read just one cylinder)
If placed at less than 12 inches from the exhaust, reversion pulses may pollute the signal, thus creating improper O2 readings at low RPMs.
Down stream of the collector also works well. Keep as close to collector as possible for fast response. Especially if you are going to plug the O2 input into a EFI system at some point.
When we dyno an engine, we have found this works the best. We have also used a Horiba 5 gas analyzer to compare with the several aftermarket O2 sensors. When placed as explained above. The comparisons were very close.
NOTE: If you are ever going to install a EGT gauge. Now is the time to weld in that bung. (On the other side) They are a great tuning tool. And keep the driver in the know as far as cooking his engine. And it really lets you know what happens when either fuel, timing, secondary ignition or load is changed. Kewl tool.!!!!
(A quad gauge and 4 senders is the cats meow. $$$$s)
Thats my experience. Yours may be differant.
C
