If I only had 1000 dollars to spend, what do you recommend?
I really don't know what "I" would do with a G spot.
Now that you have me thinking in that direction.....
And assuming I was the installer and i was gunna spend a K note on my car.
First, i would buy everything that I could either slightly used or at some killer price from the the net. I would spend time finding all the components that I would need fpr the build.
Probably take a month or so of looking on Evilbay and craigs list and wherever I could find a smoking deal on parts.
The speakers are the hard part as they usually come in high end home audio.
(cept the woofers)
I would draw out a very generic plan. Assemble the system in my head as far as speaker placement and options for that specific part of the build.
As this is a learn as you go part of the process.
Gut the interior and gas tank.
Get used to the idea that I am going to cut holes in my car. And I need to be OK with that part of the plan. Nothing structurel. It just IS gunna happen to get this right.
Then build, place and test... then build, place and test some more.
Until I have a great notion of where the final speaker placement will be.
Then build the appropriate eclosures, install the drivers. Jury rig the amps and active components. Start the car and see what and where any hum is coming from. (if any)
Mitigate that issue.
Leave the install of the 12 till last. As it might not be needed. And i would have to seal the front trunkas it would now become the speaker enclosure for the 12.
Then take a look at permanent placement for the electronics. As the spekaers would already be ball parked on placement.
Make the speaker enclosures as invisible as possible from the cab area.
(do-able, even hidden)
Start to hardwire and fasten down all components. Fix ALL the rattles in the car as the subs will rattle everything to tears and create terrible accoustic anomolys.
Install whatever sound deadening wherever it is needed.
(I like Neoprene for the big pannels that won't see water, 1/6th thick foam and lead tape for the tight spots like doors and under dash and low expansive structurel spray foam for the hollow places I can't get to)
Get the upholstery, and cosmetics figured out and pull the trigger on the final install.
Install now done 95%.
Go hit the "Bruel & Kjaer RTA" and check all speaker alignments, DB spread from left to right and center at head level, and accoustic (Hz) waterfall curves. (MLSA)
Finish by tuning by ear with and without a passenger. Check it on the road and in the parking lot.
Beat the shit out of it and tweak again....
Then stop the madness as it is never done. As air temp, humidity and ambient sound (noise) changes the accoustics greatly.
Now enjoy.
Now I remember why i don't do this often....
I better shut up now.... cause this all starting to make sense.
Hey.... How about them Dodgers...??????????????????????????????
Cheers,
C
