QUOTE(GeorgeRud @ Nov 25 2006, 03:49 PM)
Depends if you have the early or late style shifter. Unbolting and lifting the shift tower up will release the early style shiftrod, the later ones have the rod bolted to the end of the shifter. Either way though, you have to unbolt things and pull it back through the firewall if you want to replace all the bushings (which is the whole idea anyway).
Kinda what i thought. Its a tail shifter, by the way.
Thanks for the help!
