I thought that the outer and the inner were identical...BUT if someone has a set of axles out....can you check which joint (VW0 or VW1) goes to the tranny side or the wheel side?
Thx -L
Mueller
Nov 25 2006, 08:43 PM
there is no differance between the inner and outer CV joint...the different markings you see are more than likely just for manufacturing id
CHAFF
Nov 25 2006, 08:45 PM
Thanks man, I thought so cause they're physically identical.
Cheers
-L
QUOTE(Mueller @ Nov 25 2006, 06:43 PM)
Mueller
Nov 25 2006, 08:48 PM
QUOTE(CHAFF @ Nov 25 2006, 06:45 PM)
Cheers
-L
manufacturing tolerances.....
