A friend of mine is bringing his baby home to Durham NC tomorrow. He is leaving from Hunstville, AL in the morning and traveling up through Cleveland, TN and through the Ocoee/ Natahala area. So if you spot a red teener, give a wave.
JPB
Nov 26 2006, 06:32 AM
Richard Casto
Nov 26 2006, 08:35 AM
QUOTE(Brett W @ Nov 26 2006, 02:10 AM)
If he doesn't already know, point out this thread to him. All of the 914 owners in his area are trying to setup a local support network...
Done. He just called and said he lost the starter side of the ignition switch. With no tools he will try push starting. If need be I will be driving up to bring aid.
maf914
Nov 27 2006, 08:01 AM
QUOTE(Brett W @ Nov 26 2006, 10:28 AM)
That sounds like a typical failure. I've replaced the white nylon plastic portion of the ignition switch twice in the past. The failure symptoms were an increasing reluctance to start with the switch in the start position and when it would fire the engine would die when the key position returned to the ignition position.
RON S.
Nov 27 2006, 08:06 AM
Me thinks some one is gonna take a ride on the "Tail Of The Dragon"on his way thru.
ron
Brett W
Nov 27 2006, 11:56 AM
well he made it home safely. The car is tucked in its garage. He just left the car running while he filled up, so he didn't have to push start it again. Yeah I figure that switch is going out again. I replaced it a few years ago. I told him to run a new heavier gauge wire for the starter and replace the switch. He should be good to go.
