Working on removing the shock from the trailing arm. I don't have a big enough wrench for the bolt that holds the lower shock to the trailing arm. What is size wrench do I need?
Looks like another tool run to Sears
- Garold
seanery
Nov 12 2003, 01:23 PM
do you mean the lower shock mount with the rear sway bar ball mount?
27mm
GaroldShaffer
Nov 12 2003, 01:26 PM
yep that's it.
Rusty
Nov 12 2003, 01:27 PM
Channel locks.
seanery
Nov 12 2003, 01:28 PM
27mm is also the steering wheel nut size.
Did you ever get that situated?
GaroldShaffer
Nov 12 2003, 01:40 PM
Yep, it was missing the washer.
Qarl
Nov 12 2003, 11:59 PM
Adjustable crescent wrench!
redshift
Nov 13 2003, 12:02 AM
QUOTE(kellzey @ Nov 13 2003, 01:59 AM)
Is that metric?
M
