so my car's been smoking since i got it running- i drove it hoping it would go away- no luck- now it doesnt look like oil smoke (well it does but it doesnt smell like it or behave like it) it doesnt smoke under conditions that most oil burners have done it in my experience... anyhow- i thought it could be a stuck injector- so i pulled the injector connectors one at a time while it was running - one of em resulted in absolutely no change- the rest all changed quite a bit- so i'm thinking that one is stuck open... anyhow i'll try some fuel injector cleaner and see if it helps... any other ideas? i guess i'll do a compression test too.
anyhow- was at pick and pull and found some cool things- found 2 brake calipers off a 320 i (on half off day! 9 bucks each!!) a wierd carb conversion plenum for the 914, a center arm rest out of one, and a door limiting dealio too! good day- all for 25 bucks!!!
