QUOTE(ahdoman @ Dec 1 2006, 07:20 PM)
Hey all,
Since I started this thread I thought I'd let you know where I'm at.
1st - The distributor casing was 180 degrees out. So I turned it around, plugged in wires and it works but still not running good.
2nd - hook up my timing light, start the engine, look into the hole...where the heck is my TDC mark
? I shine the light way down into the right side of the fan shroud and I can see my TDC mark about 30 degrees south of where it should be
3rd - turn off the engine, pull the rocker arm cover and mechanically set my engine at TDC. Look into the timing hole and there is my TDC mark!
4th - Where am I now? Pulled the distributor and getting ready to do the McMark grab the drive and twist. Unfortunately do not own a tappet puller so using the needle nose method or maybe try a magnet? Wish me luck cause I really don't want to drop the washer! Any other words of advise?
Advice? Yes. I still seriously doubt your distributor drive gear is 180 degrees off. Before you try to pull it, check this first.
You keep saying "set my engine at TDC". You need to make sure that #1 cylinder is at TDC. That's what the notch in the top rim of the dizzy is for (#1 cylinder).
You checked that the valves for #1 cylinder were both closed and then you found your timing mark? If so, that's great. Proceed to the next step.
Once you're at that point, pull the dizzy cap and check the position of the rotor. The rotor should be relatively close the the mark on the dizzy. It doesn't have to be pointed *exactly* at it, but 10-15 degrees give or take.
If at this point that mark on the dizzy is pointed almost totally towards the rear of the car, then your dizzy is either not fully seated in the slot in the distributor drive gear...
OR
You distributor drive gear is 180 off.
Now, before you go pulling the distributor drive gear and turning it 180, verify the following:
The drive gear has a slot in the top (that you can see from the pics in the classic thread mentioned earlier) that is offset slightly from centerline. The dizzy can drop into the hole only partially and not be seated in the slot but yet still get 'hit' by the slot in the gear and the car will run, albeit not well. You need to make sure that the dizzy is fully seated in the slot. Look at the slot offset, and the cog offset on the bottom of the dizzy and gauge the relative postion of the dizzy to the slot and then refit and make certain the the dizzy is fully seated in the drive gear slot. If this checks out OK and the dizzy #1 notch is still pointed at the rear of the car rather than somewhere towards the front of the car, then your distributor drive gear is definitely off 180 degrees.
Clear as mud?
