I am tall, about 6'7, and I have a little bit of trouble fitting in my car comfortably...I am in the process of rebuilding it with some modifications, one of which will be a cable shifter which i can relocate a bit if necessary. I was thinking about taking out the pedal board and shortening up the clutch and the brake pedals somewhat..(using a subaru drive by wire gas pedal, also relocated.) and maybe pounding the firewall back a shade for an extra inch or so and putting on a steering wheel extender...
has any one else run into similar issues? How did you correct? I would prefer leaving my feet attached...
